Kjackson's avatar
Kjackson
Slide out Adjustment
My slide out is a Lippert hydraulic unit, the problem I have is the bottom of the slide is out farther than the top. When I bring the slide room in the top comes in and stops while the bottom continues to move. I have read the adjustment manual but not sure which adjust ment to use, has anyone done this?
  • When the slide is out the bottom on the inside is tight but the top leans in about an inch.
  • Does it fully touch/seal top-sides-bottom when extended?
    Does it fully touch/seal top-sides-bottom when retracted?
    IF SO......nothing wrong
    Both of my hydraulic slides do same.....top touches then bottom pulls in.
    Slides are floor flush (ride up and over main floor when retracting)
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
