dougrainer
May 31, 2021Nomad
The "wipe seal" will NOT stop water from being pulled into the RV when retracting in Rain or if you have an accumilation of water on the roof. If you do not have a slide cover, this type cover minimizes water intrusion when retracting. If you can, you ALWAYS want to level the RV with the slide out side of the RV slightly(1 inch) lower than the other side to help water run off. If you have slides on both sides, this you cannot do.
PS. Are you stating water comes in AFTER fully retracted in rain?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
