mccoydetlef's avatar
mccoydetlef
slide out sticks on one side
promblem with slide
  • My guess, broken shear pin on the right jack screw drive. Right side is just spinning, while the left is working as it should
  • mccoydetlef wrote:
    ok here goes 1998 american tradition went to pack up last week slide came in 3 inchs stoped motor worked fine brought back out came in a few inchs lookked it over on the the metal on the corner bunched up cut away metal came in next day tried to bring out started but stopped motor labored left side came out not right got crooked brought in then unlocked the motor used a rachet and pushed on inside came out looked again it seemed swollen ok any other ideas or happened to you
    Kind of looks like a voice to text translation. Here's how I read it.
    Okay here goes I have a 1998 American tradition. When I went to pack up last week the slide came in 3 inches and then stopped. I reversed the direction and the motor worked fine and brought the slide back out. I tried to run it back in but it only came in a few inches and stopped. I looked it over and noticed that the metal on the corner was bunched up.
    The next day I cut away the metal and tried to bring the slide in. Again it started out fine but stopped and I could hear the motor laboring. I noticed that the left side of the slide came out but not the right said so it got crooked and bound up. I managed to use a ratchet to unlock the motor while pushing on inside of the slide and it came out. I looked again it seemed that the seal was swollen. Does anybody have any other ideas or has this happened to you?
    Op I've never owned a slide so I probably can't help much. But when you say the metal was bunched up were there any obvious signs of impact? Was this a top or bottom corner of the slide?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
