I couldn't tell, from profile if your slide is electric or hydraulic operated.
Suspect it is electric.
You didn't mention noise. It may be a breaker or fuse. Look in manual for fuse or breaker location.
If it was still making noise it could have sheared a pin on the gear that moves ths slide on the geared rail.
I don't think it is hydraulic operated.
For any electric issue get a small case with fuse puller, for the several sizes, most usually 2,5,10,15,20 amp auto type fuses. They have them at auto stores or did pretty cheap.
Failing fuse or breaker, and pin which you won't have get a mobile tech to come check it out, if convenient.
He will tell you what it is and may be able to fix it right there. If it is the motor it will probably have to be ordered but if itis a common occurence, for your RV he may find one quickly.
