jodeb720's avatar
jodeb720
Slide Out Struggles
A fine evening to all of you -
my 2010 Keystone Cougar 244RLS has a "challenge" with the slide.
I thought the issue might be related to the lack of lubrication inside the jack screw assembly which moves the slide in and out, but after removing the entire assembly this afternoon, it's working fine (though the Motor's grease has almost dried out - it's not the reason it's on sliding).
I had hoped this was the problem, but it's not.
The bottom of the slide, in the center is dragging in and out of the 5er. I've raised hte slide up about 1/2" to see if that would help, but it doesn't.
I've seen on some of the other Keystone products, they've put roller assemblies that allow the bottom of the slide to roll in and out of the side wall - but LCI want's a fortune for the roller assembly (and it's just one small roller 5" wide).
I'm thinking if I fabricated a roller assembly with a bunch of small sealed roller bearings I could put it across the most, if not all the frame where the slide goes in and out of the wall.
Has anybody done anything like this or am I starting from scratch?
Thanks in advance!
josh
