SouthTXEMTP's avatar
SouthTXEMTP
Slide out wiring
Hello,
I have a 2008 R-Vision trail lite motorhome. One of my slides stopped working and I have narrowed it down to loss of +12V. The controllers (3 of them) are located under the sink. I tested power coming in to all 3 and the one giving me problems is the one without power. The other two slides are working just fine.
Does anyone know if there is a fuse block somewhere near the controllers? Any suggestions where I can look and see if I can find the source of the open?
Thanks,
Oscar
1 Reply
  • After a few weeks of troubleshooting and some tools, I found a faulty relay under the RV near the main battery. I used a wire tracer to find the signal from the bedroom controller to the power relay. Once I found the relay, I used a multimeter to figure out there was no power going through the relay. I changed out the relay and it all started to work again. Just an FYI for anyone having similar problems.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
