JOHN5206's avatar
JOHN5206
Slide power source
Do the slides run directly off the house battery, when hooked to shore power?
  • Hi Doug
    Yes positive - speaking for my chassis and a few friends chassis all Itasca's
    A quote from the service manual
    "Chassis Battery
    The chassis battery is used to operate the
    engine starter and automotive accessories and
    controls found on the instrument panel. The
    slideout room systems and the electric step are
    also connected to the chassis battery."
    I am sure you are well aware Winni has great detailed schematics for most of their stuff. The amount of detail they include has made the several modifications I have made over the years a lot easier. Both Winni and Workhorse IMO have wonderful easy to understand documentation. Both of them are "as built" detailed documentation for my coach.
    Like several others I added a disable switch for the "boost" relay connection activated by the ignition switch. I do not want or need the alternator to charge my house batteries all the time. The 560 watt solar system does that for me.
  • dougrainer wrote:
    RJsfishin wrote:
    Mine run off the chassis battery
    Are you positive? Some think since the engine or key must be ON and the parking brake set, then the chassis supplies power to the slide motor. But, MOST OEM's wire the actual slide motor system to the coach, but have a relay that requires the Chassis system to be engaged to operate the slide room. Doug
    Yep, positive, I can see it. But probably only because the chassis battery is close to the pump. The house batts are 12ft away.
    But, in actuality, once the key is on, its running off all the batteries.
  • dougrainer wrote:
    If 12 volt electric motor slide system, then NO. The battery is usually required to be installed and charged up, but the slide system is wired to the 12 volt breaker panel supply. Most slides require both a charged up battery AND connected to 120 shore Power(Power Converter) for optimum operation. Very few Slide systems are wired direct to the 12 volt battery posts. Doug
    Based on several replies so far it looks like your belief that few slide system are wired direct to the battery might not be correct.
    The electric slide on my 2007 HR trailer is wired directly to the battery thru a separate 30A auto resetting CB. There are 3 hot wires hooked up to my battery on the tongue. One goes to my electric jack, one goes to the converter thru a 50A auto resetting CB with the converter side of the CB having a separate wire that goes back to the charging end of the 7 pin connector and a third wire that goes to my slide thru a 30A auto resetting CB. If I disconnect the wire to the slide at the battery I have no power to the slide even if on shore power.
    IIRC I have seen several posts of other owners with a similar setup as mine with the slide wired directly to the battery via one of the stand alone auto resetting CBs.
    Here is a pic of the two CBs that are mounted just after the tongue to the floor of my TT (note: this was before I replaced them and sealed them to correct the corrosion problem seen in the pic)
    Larry
    Larry
    I stated VERY FEW, not all. Yours is wired to the battery thru a 12 volt circuit breaker. GOOD. But it just confirms MY post. I have worked on slide systems for over 25 years, and my post was the reflection of the majority of slide rooms. Now, on your system, the odds are the POWER to the system is direct to the battery, but the wall slide switch and controls will be fused at the RV main 12 volt fuse center. A LOT of slide rooms, the power is fused at the 12 volt fuse center. Doug
  • Thanks for the good info. You have answered my question. Mine is wired like the HR pic.. Need to look at my batt., it is 4 yrs. old.
    Slide doesn't have enough power to pull itself.
