dougrainer
Mar 31, 2016Nomad
The plain fact is, your aftermarket material is too heavy/thick for a good taut install. FYI. I never use aftermarket material because, if this type issue comes up, then the customer will expect ME to fix the issue. When the only fix is to install Carefree/Dometic OEM material. Doug
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
