jeeperdude10's avatar
jeeperdude10
Slide Topper Replacement
Our '16 Bounder's living room slide topper has come un-sewn from the attaching implement to rain gutter thingy. I am wanting to replace, but are in transit to destination and am wanting to remove completely and leave just the roller tube till we get to destination and have mobile replace. Is that a doable option? Should I just leave it till it is time to replace? I cannot tell if it is actually "flapping", as do not hear while traveling....your thoughts??????
  • Ivylog's avatar
    Ivylog
    Explorer III
    Pin the tube, slide the fabric out, have it resewn, and reinstall.
  • Search YouTube for example of replacing slide toppers before you begin your project.
    There's plenty of fabric there. If you can find an awning shop to cut a few inches off and resew the bead, you'll get away cheap. I did that a few years ago and they charged me $25 for 1/4 hour labor.
    Be very careful handling that awning with the spring tension it's under. You may be able to put a pin in the shaft to keep it from turning while you work on it.
  • We removed our awning when it did that. The fabric was good but the stitching had sun rotted. You can actually re-sew everything with UV protected outdoor threading and put the awning back up. You don't have to cut anything to get it down, just slide it out of the track at the top where it fastens to the rv.
  • I don't see any issues with removing the fabric. Especially if you plan on having it installed somewhere. They should be able to set the preload for the awning fabric when they install the new fabric.
  • If you cut it free and it doesn't have any kind of anti-billowing device, make sure you count the number of turns it makes while the spring unwinds so you know how many turns to give it when you install new fabric. You'll have to hold it tightly with your hands (very doable) to make it to turn slow enough to count.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
