buylow12
Jan 08, 2016Explorer
Slide won't come in!
I noticed recently that our slide seemed to sag towards one side. So was taking a closer look today to see what the issue is. It looks like a number of screws have broken off. I tried to put the slide in to see if it would bring the pieces together so then maybe I could put new screws in but it barely moved, and in fact I don't think it moved at all on the one side. I'm not sure how long those screws should be or what the are screwing into.
After looking at it for a bit longer it seems that the broken screws are probably just a symptom of the real problem. It seems that the one side has maybe come out too far and is therefore maybe an inch lower so then when I try to bring it in, it's unable to slide. I could also feel some movement when I step on it, which I never remember. I'm thinking maybe it needs to be jacked up and adjusted?
I don't know diddly about how exactly slides work so I'd appreciate any help or advice you can give me to diagnose and correct this.(I've got t- one week :) I also will post some pictures.
Thanks,
Tim Czarkowski
TotalTravelers.com
This thing came out of place.
A nice gouge mark that I don't remember seeing.
Not related but I just noticed this too... Just need to replace or could it just be reattached?
Here you can see where the screws broke off and there is now a gap. This is how it looked when I tried to put it in.
Another shot of the gap when it was fully out.
This is from the side that still moves a bit.
This is the side that doesn't seem to move at all. Instead of sitting on the white part like the other side, it's completely off.
Just another shot around the middle.
Thanks,
Tim Czarkowski
TotalTravelers.com
