itzaqueen wrote:
Doug
It is a 1997 Hurricane Class A motor home. It had carpet and we took it out and installed a thin laminate wannabe pergo. It slides over it nicely, but leaves a small scrape at each end roller. But now that the glide has been tapered with, it's hard to say it would work at all. But thanks for your response.
The problem may be that the type rollers installed were designed for rolling over carpet and NOT a hard surface. So, once you remove the carpet, the rollers will mar the surface. You may have defective rollers or maybe you can find some new rollers to fit on your slide. Doug
