Dutch_12078
Aug 05, 2017Explorer III
Slide switches commonly have 5 wires attached, 1 that supplies 12-volts, and 4 that go to the slide motor/brake assembly. None of the 4 that go to the motor are "live" except when the switch is pressed. Most likely in your situation, the wire supplying 12-volts is routed separately from the other 4 wires.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
