- BurbManExplorer III
Bipeflier wrote:
Some older units didn't sit flush. We had a 2002 that the slide set up about an inch or so. Our 2003 and later units had flush floors with slides out.
LOL we are just the opposite....our 2002 Sunnybrook had a flush floor slide that dropped in a recess when fully extended. Our 2008 Terry does not. - BobboExplorer IIIMy slide's floor is about an inch above the RV floor. I never even thought about it.
- mcheroExplorerMake sure it's extended to the proper distance. So many differen slides/models now. Our 07 era full slide will flush with the floor.
When our slide extends their is a lip with a seal on it that should be "1/2 crushed" against the interior wall when the slide is extended, aka it's proper "stop point". - HamnetExplorerThank you all. I have a 2001 skyline layton 5th wheel. It sounds like the floor was always a little elevated. I guess mine is as it always was.Thanks again
- donn0128Explorer IIFlush floor slide rooms did not become the norm until maybe 10-12 years ago. So if your rig is older it is quite possible that there will be a step up between the main floor and the slide room
- BipeflierExplorerSome older units didn't sit flush. We had a 2002 that the slide set up about an inch or so. Our 2003 and later units had flush floors with slides out.
What year, make, and model are we talking about? Are you sure the slide was completely out? - BumpyroadExplorerdepends on the construction and design of the slide. Newmar originally had one that slid out and down to make it even. that left a dreadful path thru the RV when in, one foot was about 6 inches higher than the other. my chieftain slides did not drop down, but the cabinets/bed/etc. were designed so it didn't matter.
bumpy - HamnetExplorerYes. I do mean even. Unit in storage unavailable for pictures at this moment. I posted at that last moment while in forum. Sorry I don't have pictures.
- donn0128Explorer IIFlush? Do you mean even, flush to the main floor, exactly what? Pictures would help.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
