road-runner
Mar 16, 2020Explorer III
Some electric slides use a relay and/or controller, and some don't. Those that don't have a relay use a polarity-reversing switch wired directly to the the slide motor. In a trailer, the system "might" use a relay and/or controller. In a motorhome, it "probably" does. If you're able to see the back of the slideout switch, that will give a clue. If it's a double pole switch with 4 or 6 lugs, it's likely a polarity reversing switch wired directly to the motor. Short of just figuring it out, the OP is doing the right thing asking for somebody who knows with the exact model rig.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
