BB_TX wrote:
Most likely an Auto reset circuit breaker.
When they start going bad they over heat, open up, cool down, reclose, over heat, repeat. Will probably be located near the battery and pump area.
Cheap and easy to replace. Available at RV stores and many auto parts stores. Look on the side for the amp rating.
As far as the fluid it should be near the top of the tank when all slides are retracted.
X2
Auto reset CB
Also battery voltage dropping off when operating slides
Check the hydraulic reservoir level with slides IN (retracted)
Should have a full mark on reservoir
Typically they use ATF (automatic transmission fluid)
Owners manual/pamphlet OR contact mfg.
