agesilaus
May 22, 2018Explorer III
OK the image did not come thru. Generally if you can get the leaking part off, then take it to a hardware store and get a replacement. If there are threaded parts then you need to use telflon pipe tape on the joints before threading them back together. Get the tape at the hardware too. You just put a single tight wrap on any exposed male threads. By threaded I mean internal pipe threads not external threaded fittings that hold tubing together. No telflon on those threads.
If the parts are not threaded then it get a lot more complicated and what you do depends on the type of material the parts are made of.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
