wanderingaimles's avatar
Apr 07, 2021
slightly different solar qx
Am looking at solar on a small class A.
I currently have 3 group 27 batteries (rv/marine) for the house. (prior owners had just installed 2 new, and I had one from a trolling motor setup) they will be replaced in about 2 years with 4 GC-2 batteries.
I have run across a 325 watt panel , which is at approximately double the voltage you see on the typical RV panels.
Am I correct that a 325 watt panel at the following specs is approximately 4 to 6 times the charging capability as compared to a normal 100 watt panel from renogy or another small panel?
REC - TwinPeak2 Mono - 325W Solar Panel
Dimension (mm) 1675(L) x 997(W) x 38(D)
Net weight 18.5kg
Module efficiency 19.5%
Rated Maximum Power (Pmax) 325W
Current at Pmax (Imp) 9.56A
Voltage at Pmax (Vmp) 34.0V
Open-Circuit Voltage (Voc) 40.3V
Short-Circuit Current (Isc) 10.15A
Nominal Operating Cell Temp. (Tnoct) 44.6°C
Maximum system voltage 1000V DC
Maximum series fuse rating 25A
Model REC325TP2M
Manufacturer REC
I believe it should easily be enough for my planned usage, or, should I buy 2 and also due to the higher voltages, what should I get for a charge controller?
  • 100W vs 325W is 3.25 times the power.
    You need a MPPT charger for the 325W panel which converts the panel amps and voltage to the battery amps and voltage. For a discharged battery 325W/14.8V = 22A (maximum) charging minus wiring and controller losses.
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
