BFL13 wrote:
Thanks. With all that in mind what about Randy at bestconverter saying that the current limited converter does not need a battery fuse?
" The 12 VDC output wiring does not require over-current protection because the Converter/ Charger limits current output. However, all electrical connections need to comply with the appropriate NEC code."
(from his Boondocker product manual)
Getting further off topic
Current limiting in a charger is nice
But has nothing to do with supplying 82 amps into a 2000w inverter with 6ga wire, which is were this discussion started
