blueh20's avatar
blueh20
small elec/ceramic htr/solar?
I am running 3 renolgy 100w eclipse panels on top of my 2014 ford e250 van with 40a commander and a 255ah lifeline battery.
Am wondering if a small elec/ceramic type htr would work for occasional use, take the chill out of the air in the van, maybe 15 minutes or so couple of times during the night in freezing temps ?
or is this too harsh of a drain on the battery?
really dont want to go propane if i dont have to.
I have a four led lights that draw 1amp
arb refer
usb charging port
and flowjet water pump pulls 7amps at full pressure, which is rarely used.
Is their a 12volt elec htr out their or is an inverter needed?
Any other options?
thanks for any input
  • No. That's way too much draw on a single battery to do much good. Heck, you'd even have to watch the amp draw using the fan on a propane furnace.
    You'd be better off with a portable propane heater like a Mr Heater. They really work well.
  • Have you determined the amp draw of the heater? 750 watts, the low setting on my heater, is 6 amps at 120 volts...and 60 amps at 12 volts plus the inverter’s draw per hour of use. What do you get?
  • I would think that most electric heaters use 12 amp maybe as high as 16 amp. at 120 volt. For the same amount of heat, as volts go down the amps go up.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 13, 2025
