BFL13
Apr 05, 2015Explorer II
To finish up the AH report, the 24 hr run came out at 29.4AH or 1.23a which is 28% time on when it is at 4.4a.
However the camper was not heated and ambient was below 50F daytime and down near freezing last night.
I expect the results this test are a bit low for daily AH in real life, but the test did its job of proving the need for additional battery charging even at the 29AH rate.
It also gives an idea of how much solar would be needed to compensate for the fridge, assuming you know what sort of AH haul particular solar sets can do where and when you will be camping.
Anyhow that's that solved.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
