j_p_f_
Feb 09, 2017Explorer
on the link that shows the king gen if you look above the pull starter on the gas tank you can see a small cut-out in the tank lip.
look there and you will see a phillips head screw, this is an adjusting screw for the governor. when under load if the voltage drops low adjust that screw and you can adjust the voltage some.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
