BFL13
Feb 09, 2017Explorer II
time2roll wrote:
My recommendation stays with Honda 1000 or Yamaha 1000.
As for the shootout... both the PH and King can be shot ;)
So that recommendation includes getting a bigger storage compartment in the Truck Camper, or shooting a dog or two, so there is room enough for the Honda. :)
I could get a utility trailer to go behind the Truck Camper, and make that into one of those Power Stations like some folks do. Take the Honda 3000, an inverter/ battery set, topped off with a solar panel---
"Remember what I said , maybe optimised at 110~115 volts
99v and 38 amps what was the difference in power factor efficiency? "
I should run the King with the 1093 set to 20 amps and compare those numbers. Get to that later on.
Is there any "issue" with the Kill-A-Watt on the non-inverter King for reading voltage? It was clarified that the King is not MSW, but still-- I see its freq is a little unstable on the KaW but it holds its revs under load--ISTR that 3,600 is for 60hz?
--If I play with that governor to hold the voltage up, would that screw up the Hz and would that matter?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
