roypd's avatar
roypd
Small leak in windows
Sorry if this is the wrong forum for this, but couldn't find a better fit. Just purchased a new Hideout 27DBS, and as many of you are probably aware, the East Coast got hammered by ran over the past week or so. Since we had the trailer in our side yard, I decided to check on it every once in a while - being new and all.
Well, I noticed that 2 of the windows have what appears to be a small leak. I know the windows have a track in the bottom where water tends to collect and drain out the weep hole. Well, on 2 windows, the top is dripping. It sort of drips and splashes, so it doesn't all get into the track at the bottom.
Looking at the top of the window from the inside, I see some plastic strips inside the track that are screwed into place (see pictures). Where one of these screws are is where it is leaking.
Everything looks good from the outside. There look to be weep holes at the top of the window that are capped with a strip of plastic. Not sure if water is entering there and then traveling to where the screw is inside or what.
Any ideas on troubleshooting? I'd hate to make a long drive to the dealer for something that may be simple.
The pictures suck, but I tried to show where the leak is and the screw I speak of. I can get more if needed. I figure this window design is common in the trailer/rv world, so hope someone has some advice. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
