AStinker-'s avatar
AStinker-
Small Residential Freezer
How would you calculate how many amp hrs would be needed to run a small residential freezer for say 12 hours with an inverter when you (with out buying it and testing it) when you have no idea how many hrs. a day it will be running?
All I can find out from Mfg. is it pulls 1.29 amp when running, the start up current is 3X run current and annual energy consumption (from energy guide which they STRESS is just an estimate) is 240 KW/Year. I have trouble believing the 240KW/Yr. I understand starting current is a requirement for sizing the inverter but is not a big factor in total power requirement. And I'm not real keen on buying it an testing it. Would you use a multiple or some factor of the annual energy consumption? Need your expert advice.
