could be he meant on an 'Inverter' circuit, usually
NOT a good idea
SoundGuy wrote:
Larry-D wrote:
We are using the Vornado. One goes to an outlet that runs through the trailer's converter.
No 120 vac feed runs "through" the converter ... rather the incoming main service feed is wired to an input buss that happens to be located in the converter (or power center as some like to call it) and that buss feeds a variety of breakers. Usually one of those breakers then feeds the converter while other breakers feed other 120 vac circuits in the trailer - receptacles, A/C, water heater 120 vac heating element, etc, etc. However, none of these circuits go "through" the converter itself which has no control over any of the 120 vac circuits.
