mrekim's avatar
mrekim
Smart Charger Voltage 15.9 volts ? (VEC1093DBD)
I just got this charger. When connected to a mostly charged battery (12.4 volts) I've notices that it seems to charge at 15.9 volts - low current 3 amps or less. This seems too high. It's running outside, 17 degrees temp. This is the voltage as reported by the charger, so it knows it's hitting that level.
I wonder if I should ever see such a high voltage in a regular charge cycle?
Also, it seems like this charger may not be safe to use on a battery that is hooked up to a trailer or car?
Having RV issues? Connect with others who have been in your shoes.24,296 PostsLatest Activity: Aug 08, 2025
