BFL13
Jan 24, 2014Explorer II
mrekim wrote:BFL13 wrote:
It should be around 14.8 at 68F.
If you have somehow hit Equalize (green light flashing) by poking a pin in the hole for that, then it would go into the 15s (15.7v nominal for Equalize.)
Nope, it's not in equalize.
I went and got an IR temp meter. I was off the temp in the basement. I shot the battery and the charger and got 55-56 degrees. Doe that seem more reasonable for a regular cycle?
The table I have for equivalents to 14.7v at 77F is that at 55F it would be 14.99v. So it may not be that far out of whack, but at the high end of whatever its +/- margin of error is?
I have not done a calibration check on mine but it certainly does the temp comp. It will go over 16v in Equalize in cold temps.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
