BFL13
Jul 19, 2014Explorer II
Smashed Solar Panel Still Works (sort of) Question of Rain?
Last year I sold a guy here my two 100w panels that were surplus. He set them up as a portable stand deal for the pair, works great. Yesterday we had a big wind squall and it flipped over his panels and one panel hit a rock really hard. Oops.
The damaged panel has all its glass shattered/cracked into little tiny bits like a broken car window, but still all bits in place covering the cells with a really bad spot more opaque where it hit the rock. Also the cells in the bad spot have a bulge there while the rest of the panel is still flat mwith cracked glass everywhere. Ugh!
Taking out the multimeter set to amps, the good panel as aimed away from the sun a bit, got 4 amps (out of 6.3 rated if aimed right) The damaged panel in the set got 2 amps! He got 6 amps total from the set as it is now with the damage instead of 8. (rated for 12.6 aimed right)
I ASSume if he cleared away all the broken glass off the cells he would get full output, where the cracked glass acts as shade. However, what would happen if it rains? Does the glass protect against the cells shorting out if wet?
Can the glass be replaced with window glass to keep the rain off? Price of glass may not be worth it, but just like to know if that would solve the problem for now.
Thanks for any info on that. Meanwhile, take heart, your panels can take a licking and keep on ticking :)
