Tocwby's avatar
Tocwby
Smoking Batteries
2010 Springdale 26BHS: When I plug into shore power (30amp) I wake up the next morning to overheated batteries that are smoking and putting out that wonderful smell.
Here is some history: years ago I drove away from the house to leave and forgot to unplug my shore power pulling the cord out from the back of the trailer. I was able to reinstall the 3 wire cord to the back of the trailer (not directly connected to the converter because it is in the center of the trailer and the cord just hooks to a junction box in the rear).
I am not sure if this is related to my battery problem or not. The trailer works fine if I disconnect the batteries when I am plugged into shore power but that is getting old. Do you think I hooked up the wires incorrectly or has my converter gone bad?
Thanks for any help!
  • Tocwby wrote:
    Ed_Gee wrote:
    I wish the original poster would confirm that he has checked the water level in that battery or not!!
    I am the original poster. they are non service deep cycle batteries. I have replaced them several times over the last few years that this has been happening.
    Several times this has happened!!? Then I would certainly think your charger is overcharging the batteries! Yes, with the batteries disconnected your 12V lighting and appliances may still work.....surprising you have not had something burn out, though. You REALLY need to get a voltage reading on that charger! . .. . Or just replace it.
  • There is a universe of difference between 14.0, and 14.4 for a high antimony battery. 14.0 is too high is applied longer than 2-days at >70F temps.
    WFCO the powdered milk of dairy products...
  • OP Quote:
    I am very familier with 12 volt vehicle systems
    Is that why you didn't check the output voltage of the converter while your batteries are smoking ?
  • I am still trying to get back to the trailer to Fluke the charger and make sure but after reading all the posts, I am pretty sure that is the problem.
    If it is the charger, what are your thoughts on replacement? replace the entire converter/charger/distribution panel or just remove the converter/charger and replace it?
    Assuming the rest of the panel is not in bad shape, I'd go for the latter option. It's certainly a lot less wiring hassle to contend with.
    Bestconverter.com is a good source for the converter, and they are quite knowledgable about the various options and what would be the most straightforward for your particular panel. I'm generally a fan of the Progressive Dynamics converters myself, all other things being equal.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
