partsman01's avatar
partsman01
So curious, how quick should A/C cool air?
I ran stove, fridge, water heater to make sure all was ready for our trip in two weeks, but when I remembered to try A/C I could hear the heavy sound of it, meter in outlet showed I dropped to around 110V in the red, so did not want to run it too long drawing on an extension cord on a house outlet, but still it did not seem like the air was that cool, should I have waited longer?
I did notice if I switched to fan mode only of course power draw lessened but when I switched back to the cool mode I did not start the A/C which I think must be a protection thing, so am wondering if I should let it run longer to see if it does cool.
  • 110V is fine. But extended run time may cause the extension cord to overheat.
    ACs don't produce cold air. Rather the outlet air is 20 degrees cooler than the intake air. So 100F in and 80F out, eventually cooling the rig.
  • DO NOT run A/C on a 15 amp circuit or with a less than 30AMP cord on a 30amp circuit. Doing so will overhead the wiring, and really put a load on the A/C because it cannot draw enough power.
    Test it at the campground.
  • Start it up again and let it run - 110 is OK and won't harm your AC - I use 109 as my cut off.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
