enblethen
Jan 12, 2013Nomad
There could be water in your LP pipes. You could take loose next to the regulator and then at water heater, use an air compressor to blow them out good.
If you are going to replace the regulator, get an auto transfer type. They are a little more convient and uses only one tank at a time.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
