red31
Jan 12, 2013Explorer
Boddhisattvha wrote:
Once the tanks are empty was I correct in assuming that I just leave the valve open for a few days to let them dry out?
No
"The design of the OPD valve is such that turning the cylinder service valve handwheel will not produce any effect if the cylinder is not hooked up to an appliance. In other words, a connection must be made between the appliance hose end and the cylinders service valve. The inside of the OPD valve is engineered to only allow propane in or out if the internal valve is actuated by being depressed. This OPD valve feature adds additional safety in case the handwheel is turned, opening the valve. For this reason, OPD equipped cylinders will not allow gas out of the cylinder when opened."
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
