Boddhisattvha
Feb 20, 2013Explorer
Yep, those are the exact pig tails I picked up. Along with the autochanging regulator. At the bottom of the regulator is a line that is a little flexible and runs from the regulator to the metal piping that's connected to the frame of the trailer. I disconnected the line from the piping and opened the valve a bit to see if I am getting LP through the regulator and all that and I am getting propane just fine. So I know it's something to do with the actual LP system on the trailer now.
I found something in the piping itself that I think is the culprit.
I cannot figure out how to get the pic to load here. I haven't had to use an image hosting service in a very long time.
It looks like some kind of regulator that is probably stopping my LP flow. It's grounded and connected to a hot lead. It's in the line in between where the regulator connects and the piping runs off to all the appliances.
If you cut and paste this link it works just fine for me, but not if it's clicked on.
http://hellstorm79.tripod.com/webonmediacontents/IMG_0003.JPG
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
