enblethen
Feb 20, 2013Nomad
It is a gas solenoid that works off the LP detector.
Is your LP detector on?
What is make and model as the ICC units go bad.
Safetalert model 70-742r is a good replacement, however the solenoid needs to be changed out.
The ICC solenoid connects to both battery sources in MH. One feed is from chassis and one from coach battery systems.
There should be two grounds on the solenoid. One from each of the battery systems.
There should be good continuity on the coil.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
