RoyB
Feb 20, 2013Explorer III
The LP detector should be hugging the floor somewhere... That is where the leaking PROPANE is suppose to go... It still could be your battery dropping below 50% charge after running the blower for a long time. The furnace blower pulls alot of DC power from the battery... Mine pulls 6-8 amps when running i.e. if the battery gets weak then maybe the solenoid drops out switching off the propane...
Sure is suspect however being a solenoid controlled propane line switch with control wires going to it. Something turns its on and off...
Bypass it or replace it I reckon... My 2008 off-road trailer doesn't have anything like that in use...
Did you post the year and model of your trailer I may have missed it...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
