Vintage465
Oct 30, 2015Nomad
smkettner wrote:
You can plug the main cord into the inverter or install a transfer switch.
If you plug in direct you will need to disable the converter and make sure most other appliances are set to propane or kept off.
That is a cool idea, hadn't thought of that. Only problem with that is the main cord is quite aways away from the ideal location for the inverter.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
