Makin__Do's avatar
Makin__Do
So, Where's All the Oil Going?
Like all of you, before going on a trip I check all fluid levels. My oil dip stick indicated "full". After 527 miles I checked the oil level again while fueling up. Oil was down 1-1/2 quarts. Strange, since this engine has never need any oil before 1200 miles. Went another 400 miles, down another 1-1/2 quarts. Brought the oil level up to full again and drove another 225 miles. Down more than a quart.
It's now clear there's a major problem. What I have is a Chrysler 360, with 4bbl carb. Rebuilt by a local engine shop (bottom end, I did the top end)about 10k miles ago. It runs smooth, quiet and strong. Pulled all the plugs expecting to find at least one of them badly fouled with oil. All the plugs are fine. There are no oil spots on the ground after the rig sits for an extended period of time. No oil on the back of the rig, which might indicate the rear main seal is bad. In fact, the entire under carriage is rather clean. The rig has dual exhaust. The left side has no soot to speak of. Now, the right side is a different story. I can rub off soot with my finger. This might indicate an oil leak in the right bank. Yet, I see no smoke while driving down the road and the plugs are good.
So, where's all the oil going? Any thoughts on this?
P.S. Can't take it back to the rebuilder. He retired and closed the shop.
  • Thanks for all the replies. Didn't think about checking the PCV valve. Do that in the morning.
    Never have used synthetic oil.
    No oil in the cooling system.
    No heat riser.
    No cooling lines underneath.
    If the PCV valve isn't an issue, I'll check the intake manifold next.
    Again, thanks for your input.
  • What year engine? Do you have a catalytic converter(s)? Leaky exhaust valve guides can easily pump quarts of oil/1000 miles which doesn't go through the engine, only through the exhaust manifold and out the tailpipe. If you have an oxygen sensor with a feedback loop and catalytic converter(s), it will burn there without showing signs of blue smoke out the exhaust.
    Chum lee
  • I had a 360 turned up considerably. The design of the heads with heat crossover etc makes them run hot. The valve seals don't seem to last too long.
    I always used bronze valve guides and Moroso valve seals with its own little spring wire tension on the high temp tolerant seals.
    Some of newer engines use only 2 ring pistons and even if three low tension rings.
    I don't see a drop on the ground, or on the motor, or out the exhaust but it uses a lot of oil.It's 5.4 Ford.
    the valley cover gaskets on the 360 leak quite often, especially if the heads have been planed or cut because of warpage and no adjustment to the metal of the manifold or one piece gasket valley cover.
    Sine you don't see any signs of useage other than disappearing oil, you are probably getting oil around the rings and burned.
    Synthetic oil is thinner and usage will be more than with old dino oil too.
  • JoeH's avatar
    JoeH
    Explorer III
    RJsfishin wrote:
    What an absurd statement !
    I would suspect the valve seals were not installed correctly, or not at all.
    I haven't had a Chrysler in ages, but I've had oil consumption issues with one of my Fords.. it was even still in warranty ( 1999) . It was valve seals.
  • j-d's avatar
    j-d
    Explorer II
    Had a 360 years ago. Used oil after I sent the heads out for a valve job. Ended up replacing the stem seals myself with heads on the engine. I don't remember the brand I used, probably Victor or the like. I know they were not speed shop/hot rod parts. I remember they looked different from what the shop put on it, and I think they had little garter springs.
  • To check valve stem seals, after towing do not start the truck until the motor is cooled completely. Have some one start the truck while you watch the exhaust, if you get a puff of black smoke and then it clears up I would suspect stem seals. After shutting down a warm motor, with bad stem seals, the oil in the valve covers tends to run down the valve seals. Not really noticeable when running.
    There is the possibility that a couple of guides are worn in the one head also. Same symptoms as stem seals. Seals can be replaced without taking off the heads, guides not so much. Guides are a problem on that motor.
    As much as I hate to say it, with one side of the exhaust sooty I would suspect oil going past the rings for some reason. Could be anything from scored cylinder, won't always make it run bad, to the rings rotating on the piston. Rings do move in the glands on the piston. That is why you stagger them around the piston. After a reasonably fresh overhaul that is what I would suspect.
    I would run the truck for a couple thousand more miles, checking the oil a lot. By then the rings will rotate some more stopping the problem or you should be seeing some carboned up plugs.
    Good luck.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
