lane hog wrote:
Assuming I do a tear down and remove the seals/plastics, has anyone had good or bad experiences with small engine carbs and acetone?
I've got what I suspect is a gummed carb on my Onan 4K, after it had an unexpected time out where I couldn't exercise the gen monthly and didn't have an opportunity to drain the bowl.
The gen runs, but surges under a load and dies usually after 20-30 minutes. I've tested the fuel pump and filter, and both seem to be fine, so I'm moving on to pulling the carb and doing a soak.
Onan has a product called "4C". it is an engine an carb cleaner.
There are many instruction videos on all the various carbs on youtube.
