lane_hog's avatar
lane_hog
Explorer II
Sep 05, 2016
Soaking Onan Carb in Acetone?
Assuming I do a tear down and remove the seals/plastics, has anyone had good or bad experiences with small engine carbs and acetone?
I've got what I suspect is a gummed carb on my Onan 4K, after it had an unexpected time out where I couldn't exercise the gen monthly and didn't have an opportunity to drain the bowl.
The gen runs, but surges under a load and dies usually after 20-30 minutes. I've tested the fuel pump and filter, and both seem to be fine, so I'm moving on to pulling the carb and doing a soak.
    These folks
    Call and see what they say.
    I've never seen any coatings on carb parts that will be harmed by Acetone, If they are painted on the outside that will come off, but who wold care?
    Carb parts are usually white pot metal, and needs no extra coatings to make them fuel proof. In some cases the metal is etched with a 6% chromic acid this will leave a tea colored stain for better paint adhesion, that will not be removed by acetone.
  • darsben1 wrote:
    Why don't you try Seafoam mixed in a gallon of gas. Connect gas line to the gallon and let her rip.
    That should clean up the carb
    X2
    I have used Seafoam 50/50 this way with no ill effects. What have you got to lose?
  • X2 on carb cleaner. Small parts get soaked in cap from carb cleaner. Everything else a good spray down over a bucket. Then compressed air and blow out the passages. Watch for the seal on the needle and seat. Compressed air will force it out.
    Rinse repeat as necessary.
    JKaz
  • I'd just use a can of carb cleaner spray. If you need to soak it use new clean gasoline. The Acetone is way too strong IMHO.
  • Should not hurt the aluminum carb body
    But acetone evaporates fairly quick and is highly flammable
    I find a bucket of parts cleaner from the auto parts store a better alternative
    But for one part one time I might use acetone
  • Why don't you try Seafoam mixed in a gallon of gas. Connect gas line to the gallon and let her rip.
  • If that carb has a coating on the casting to seal the pores, the acetone might dissolve the coating and leave you with a hard cold-start situation. We called that a dry-bowl carb because all or most of the gas would seep out overnight. We would throw those carbs away.
    Go to the auto parts store and pick up some parts cleaner.
