ktmrfs
May 28, 2018Explorer III
AC motors come in several varieties. two common ones are
split phase. No starting capacitor, very low starting torque. Usually in small motors with low starting torque needs.
Capacitor start, what the "soft" start kits like supco supliment. changing the standard capacitor for one that lowers starting current but still a capacitor start motor. Cap start motors have much higher starting torque. Once the motor comes up to speed the starting capacitor is taken out of the circuit.
Capacitor start, capacitor run. they have capacitors in the starting and runing circuit. Many Air conditions have this. IIRC my coleman is cap start cap run.
AC motors have very high current inrush until the rotor starts to turn and develop a "back emf" as it comes up to speed current demands decrease. And if the motor is turning a load during startup this starting current can be quite high. RV AC motors can draw 50-70 AMPS during initial startup even with some form of capacitor, factory installed or supco.
Now to dramatically reduce the starting current there are devices such as the micro air easy start (which I do have) that keeps the starting current in the 20A or so range. Still takes the same energy to get the motor running, but spreads it over a longer period of time with lower current.
Kits like the supco are really just a different value starting capacitor. they will help reduce the starting current, but not by much in a unit that already has a start cap, which is the majority of RV AC units. It will get you from almost adequate to barely adequate. If your not in the almost adequate to start with it won't solve your problem.
I tried the supco kit. it did slightly reduce starting current and load but not enough to start the AC at other than sea level with my honda 2000. My coleman already had a factory "soft start cap" or whatever you want to call it installed since it was a cap start motor.
Kits like the micro air go much further. My honda 2000 in eco mode will easily start my coleman MachIII at 4500ft. no surge, just a smooth rpm ramp up.
What's the downside? doesn't change running current. At high altitude around 4000Ft the honda 2000 goes into overload after 15 minutes or so.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
