2edgesword
May 31, 2018Explorer
ktmrfs wrote:2edgesword wrote:Home Skillet wrote:
Over the years, I have tried all those hard start capacitors mentioned.
Nothing compares to the Micro-Air soft start.
No more generator surging when the a/c cycles, etc.
LINK
I would think if you're doing a lot of camping off the electric grid then the extra cost between a hard start capacitor ($10) and the Micro-Air Soft Start ($300) isn't an issue. For me the few times I anticipated and have had to run the A/C on a generator didn't justify the additional cost. It requires some human power management on my part (primarily no microwave while the A/C is running) but doable.
we do lot's of off grid camping and my experience with the soft start kits and a honda 2000 was it would reliably start the AC under these conditions.
1) sea level to 500ft, temps below 85F
2) generator warmed up turned off eco mode
and or course everything else turned off.
Once above 1000Ft especially with temps near 90F, it would not reliably start the AC even with the soft start kit. By 2000ft it was a 100% no go.
Now different brands and models of AC units vary, along with what generator you have.
As a comparison my second smaller trailer has a coleman "polar cub" a 9500BTU AC with a very good soft start circuit, optimized for low LRA and that AC unit I can start with the honda 2000 at 6000+ ft and any temps and run it all day long with no problems.
With the microair easy start with my Coleman MachIII I can leave the honda 2000 in eco mode and reliably and smoothly start the AC to at least 4500FT 95F, 6500Ft density altitude. generator ramps up smoothly.
Now at 6500FT density altitude the honda 2000 does run out of poop and will overload after about 20 minutes, so it did mean paralled honda 2000 at that altitude. But then I could get the batteries charged as well.
Son now has one of the honda 2000's, I have the honda 2200 so we shall see if the extra 200VA and 25% larger engine solves the altitude problem.
If a soft start kit solves the AC problem under the temp and altitude conditions you experience, go for it. If not, the micro air will solve the starting problem, but it doesn't lower running current so high altitudes may still be an issue with one generator.
If I were doing a lot of off grid camping the microair would be the way to go. I think the frequency of use versus cost factor is a major factor in making the decision which way to go.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
