pianotuna
Sep 26, 2018Nomad III
* Muses about the size of the power brick for a roof air conditioner * LOL
Why would moving the voltage trigger point up cause chattering relays? The distance between the set points would remain the same.
I'd love to have the funds for a high amp capacity isolation transformer. In fact my cousin used his to check the set points on the Sola Basic. His is intended for low wattage items so we did not check voltage under load. Nor would it get up to the 135 buck voltage.
I did email the company tonight. Perhaps I'll get a reply--if so I'll post their reply here.
I do know from other threads that the Pot does exist, and that others have changed the value at which boost occurs. I just hoped to know which one. That would make my cousins life easier.
I am aware that changing the set points won't increase the boost voltage.
I do find the Sola Basic useful. Running heaters in winter time at a boosted voltage certain makes a difference. It is about the perfect size for a 30 amp service.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
