scrubjaysnest
Jan 19, 2016Explorer
pianotuna wrote:
Hi,
Buy a controller that has:
1. a temperature sensor on the battery bank
2. a voltage sense wire
3. adjustable voltage set points
I'd stick with pwm right up to 500 watts, beyond that and I'd go MPPT. At 1000 watts I'd switch to a 24 volt battery bank.
+1
I use 400 watts as the point at which to consider MPPT. Ours is PWM and because of a panel failure we will go from 280 watts to 360 watts.
PWM has always been fine for us but we tend to be on the conservative side. A point to keep in mind, the battery(s) determine how much current they can accept so MPPT may not be the best choice.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
