93ToyTruck
Jan 19, 2016Explorer
If you've got several panels, an MPPT controller will allow you run them in a series so that a higher voltage is transmitting between the panels and your controller. Less loss, you can use smaller wire and you'll get power in lower light situations. Panels in parallel might not produce over 12 volts in low light but they probably will when they're in a series.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
