Empty_Nest__Soo
Nov 29, 2014Explorer
OP here. I’m not too “poor.” Not terribly wealthy either. :) Let us say I want to spend my money sensibly.
I have a 40-amp portable charger (B&D VEC1093DBD) that I can run with my Yamaha Ef1000is to make up a shortfall. I hate to run the big Onan just to charge batteries, mainly because it consumes so much propane that I would rather use for other things without unduly shortening my stay. I hope an appropriate amount of solar can minimize the need to run a generator.
I’ve been doing a lot of reading and I’ve come to a couple of tentative conclusions:
1) The first thing I should do is probably buy and install a good battery monitor so I know with greater certainty how much power I am using on a typical day and where I stand with the battery charge in cold weather. I probably also need to equalize the batteries and ensure they are in the best condition I can put them in.
2) I have concluded that shade will be more of an issue than I thought or expected. It seems that having one cell in a panel can effectively kill the output from the panel. I’m not camping in deep woods, but the campground where I camp most has enough shade to be a problem for a roof-mounted system. A portable system, one that I can move around and angle to get the best available sunlight, is probably my best alternative. As a rough guess, I figure I could get by well with maybe 200 watts if I can move the panels and point them to the sun.
Is there a good, cost-effective choice to the somewhat pricey Trimetric monitor? I’m thinking of something that can reliably tell me how many net amp-hours I’ve used. If not, which Trimetric model do you recommend?
Thanks again to everyone who has contributed!
Wayne
Wayne
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
