Amazon has a Renology 200 watt solar beginner kit for $340 with controller and a bunch of stuff . Would that be good for a dummy RVer wanting to charge two 6 volts to run a small freezer ? We use very...
GC -2's for a 10% Rate of Charge require 20 to 22.5 amps; that's 400 watts minimum. Figure out how many watt hours you need over a 24 hour period. Divide that by 12 volts to get Ah over a 24 hour period. Double that and you will be close to the amount of batteries you need. That will tell you what you need in the way of solar. Probably need a gen set for some things.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
