BFL13 wrote:
The voltage setting is both absorption and float. It gets the batts up to that and stays there till dark. I set mine to do 14.8v when camping and when not camping 13.4 as the float.
Pick the voltage according to your battery type and brand's specs.
First set-up, let it get the batts up and see what it really settles at. Mine and Niner's overshoots so to get 14.8 I set 14.3 I like this, since the max setting is 15.0 and I can actually get 15.5 If I want.
The voltage and amps on the display are accurate though. I don't use the AH or any of the load features.
So the " ceasing charging Voltage" is both absorption and float? Then this is the only adjustable parameter I would be concerned with?
Thanks very much for the help
