crcr's avatar
crcr
Solar: Add Anything to Copper Crimps & Tilt Angle for Panels
I'm in the middle of installing a solar system, and have a couple of questions:
Heavy Duty Tinned Copper Lugs crimped onto Copper stranded wire -- Use any anti-corrosive or conductive grease type material in the joint before crimping it? Or better to use nothing? FYI, I do use a high quality adhesive-based clear shrink wrap on crimped joints.
I am putting five 100 watt panels on the roof, non-tilting mounts. My question is, what is the recommended slight angle to mount solar panels for the purpose of rain run-off?
Thanks in advance for any recommendations!
  • BFL13 wrote:
    I have seen something somewhere recently not to use any goop in there like that, but can't pin it down at the moment. Was in one of the owner's manuals for something, not to use any of that red spray stuff you use on battery posts. Might not be the same as what you are asking about.
    5 degrees to get run off, but the roof may already be at that with camber.
    Thanks. Yeah, I think I read something recently somewhere also recommending to put nothing. I used to put Ox-Gard on such connections, but now I am questioning the wisdom of that.
    My roof is very close to flat, though must be rounded ever so slightly to each side. I was thinking for the two panels nearest the front of the TT, to tilt them down slightly toward the front due to forward motion when traveling, but I suppose any such angle like 5 degrees or so is so slight that it probably doesn't matter which direction they are tilted in.
  • I have seen something somewhere recently not to use any goop in there like that, but can't pin it down at the moment. Was in one of the owner's manuals for something, not to use any of that red spray stuff you use on battery posts. Might not be the same as what you are asking about.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
