JR51's avatar
JR51
solar add on and batteries
I currently have 2 renogy 100 watt solar panels and a 20 amp charge controller and very happy with equipment and output. Plan on doing more boondocking this year so am going to install another 100 watt panel. I know my controller can handle up to 400 watts. I have 2 -100 amp deep cycle house batteries. My question is with the increased output am I better off keeping just the 2 batts or adding another house battery. Thanks
New York Newbie
  • Since acceptance rates of lead acid batteries are limited to about 12.5 amps per 100 amp-hours of storage, at 85% state of charge, the theoretical maximum wattage is about 150 watts per 100 amp-hours.
    In real life, with a flat fixed installation one would expect perhaps 80% of that 150 watts, under perfect charging conditions.
    I'd recommend an MPPT controller with a series/parallel panel "farm" consisting of 4 100 watt or 2 200 watt units.
    With the advent of non sulphating batteries such as SiO2 and Li, it is no longer necessary nor even desirable to get to 100% state of charge. 1500 cycles to 20% state of charge is over four years of daily full cycles. 2800 cycles to 50% is about 2800 cycles or about 7.5 years.
    Next summer, my plan is to move to SiO2 jars. Cost is about 50% of Li and the temperature range of use for them is -40. Since I am no longer full time, the bank may well out live my ability to travel in the RV.
    Another way to size the "farm" is to base it on usage. For example, my fridge uses 5.7 kwh per day. I live in a sunny place--so a 1000 watt install with 600 amp-hours of storage would make me propane independent.
    If I abandon the 12 volt limitation, and jump to 48 volts, life gets simpler.
