Mello_Mike
Dec 22, 2015Explorer
In response to BFL13:
-Is the 240 now two 120s in parallel nailed flat to the roof? or can they be tilted? Two fixed 120 watt panels in parallel
-will the two 120s be in series with the new MPPT (which affects options for how the 100 can be integrated) In parallel
-how many amps (size) is the PWM controller? (can you just add the 100 to that--very simple then) - 30 amps
-what do you expect to gain from changing the 240 to MPPT? Need every watt I can get out of my system for my new Danfoss compressor refrigerator
-how far away from the rig will you be deploying the suitcase set? Not far at all, about 10-15 feet
-100w will do about 6.2amps aimed at high sun. Why is that considered "huge?" What do you get now with the 240 as is? It's huge for me because my existing 120 watt roof panels are fixed. Not only does this suitcase give me another 6 amps, but it's aimed directly at the sun unlike the roof panels.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
